Need some help!
I have an outside light which is wired into a light switch which is part of the downstairs lighting circuit.
I have replaced the light with a 300w hi/lo light with sensor but not sure if I have wired it up correctly as it keeps tripping out
When I removed the old light I had two cables attached to it wired like this
Both earths to the earth terminal
Both lives to one terminal
One neutral to one terminal and the other to a separate terminal.
The new light only has three terminals, I have put the two earths, two lives, and two neutrals into the relevant terminals on the new light.
When I turn the power back on the light works fine, but if I use the switch to turn it off then it trips out the circuit.
What have I done wrong, do I need a new fuse for the fuse board?
Regards
Kim Bryan
Regards
Kim Bryan
