outside pir
19 Mar 2015
London
Hi there,
I would like to install a pir to my existing light. I will be getting the supply from a socket then switchd fcu using 3core flex. I would like the light to only activate when it is dark and I approach the door it then comes on. From the fcu I will connect L and N and CPC to sensor teminals and then from sensor back to light fixture L-L N-N and CPC -CPC is this correct? Thanks
If it is an existing light, then it willprobably be powered from the lighting circuit.
Why do you want to get the supply from a socket circuit? You do realise that you cannot combine the two?
sorry what I mean is I already have the light fitting but not the supply.
