Just recently bought a Moffat Electric Oven, I have read the manual and it
says it can be installed using a plug, spur box or a cooker control circuit.
As I am currently skint I'd prefer to wire it up to a plug the problem comes as it needs a double pole switch which is currently not installed.
I have got a switch on my socket do I need a double pole switch or will the switch on the socket do the same job?
I can replace the socket for a cooker socket and then get a double pole switch on with it, is it ok to have the hob hooked up to the cooker socket as well as the cooker or do I need a separate socket for this.
What should I do? Any suggestions are welcome cheers John
