Whilst I agree that there will never be a reason for using 2.5mm² flex with a BS1363 plug (and one might struggle to get it to fit), what are you suggesting "would not permit" it?
Yes, I had overlooked extension leads. If one is contemplating a potential load of 13A, then I would think one would need 2.5mm² (if not 4mm² - and getting that into a BS1363 plug would be next-to-impossible) for lengths much shorter than 100m (depending on qhat VD one was prepared to accept). By my reckoning, the voltage drop of 100m at 13A would be 41.6V with 1.5mm² (~18% of 230V)and 24.7V (~11%) with 2.5mm².
Their instructions are ludicrous. They state that in the UK a 2.5mm^2 flex should be used with a plug and socket or FCU. 2.5mm^2 is not permitted to be used with a BS1363 plug.
Well, although I doubt that such is the case, someone might try to 'prohibit' it if they felt that the mechanics were such that 2.5mm² cable could not be safely terminated in a BS1363 plug.
As for who the 'someone' might be, I suppose there's the manufacturer's 'instructions', but what gets connected to a BS1363 plug is presumably outside of the scope of BS7671. Does BS1363 itself perhaps have something to say about this? Stillp?
I've certainly seen 2.5mm² flex connected to a BS1363 plug a good few times, and I even think I have seen 4mm² successfully crammed into one!
It doesn't prohibit anything.
Back in the days when MK were a reputable manufacturer, they used to offer a plug that would take 2.5mm² flex - I well remember them, as a lecturer at the college where I was a technician had me make a number of 2.5mm² extension leads with them.
Back in the days when MK were a reputable manufacturer, they used to offer a plug that would take 2.5mm² flex - I well remember them, as a lecturer at the college where I was a technician had me make a number of 2.5 extension leads with them.
What plugs were those? I find it difficult to get a good fit around the post terminals MK have always used with anything larger than 1.5mm², particularly the live terminal as it then tends to foul the fuse. If I have to fit 2.5mm² in a plug I tend to use Duraplug or Permaplug as they seem to take it pretty well (though not sold on the quality of Permaplug).
