I have a strange problem with my immersion heater water tank overflowing. It overflows right over the top of the tank. It does this when the bath mixer tap is running BOTH hot and cold water, but not either one on their own. Strange. Why would this be? I will explain the story below with photos to paint a clearer picture.
This is my bathroom mixer tap.
http://www.rjalearning.co.uk/delete/bathroom_tap.jpg
If I just run the cold water (from the mains) from this tap there is no rise in the level of the water in the immersion heater tank. If I run just the hot from this tap, as you would expect the level goes down in the tank and the ball valve then successfully kicks in and the water level returns to normal without issue. No problem there.
However if I turn both the hot and cold on the bathroom mixer tap, the level of the water in the immersion heater rises and eventually pours over the top of the tank. This is my immersion heater tank (the top of it).
http://www.rjalearning.co.uk/delete/ball_valve_tank.jpg
When the bathroom mixer tap is running both cold and hot water, no water comes out of either the ball valve or the grey hole or the hole labelled there with the red arrow. Water must be filling the tank from elsewhere, not from the top there. Eventually water comes pouring out of the hole in the tank labelled with the big red arrow. The water will continue to rise and pour over the top of the tank. The way to stop this from happening is to turn the bathroom mixer tap off, so no hot or cold.
I also have a mixer tap in my kitchen. I tried the same thing with the kitchen mixer tap, both hot and cold and no problem. The water does not rise. There is no issue with the kitchen tap.
This is the kitchen mixer tap.
http://www.rjalearning.co.uk/delete/kitchen_tap.jpg
So, does anybody know why this would happen with the bathroom tap? Thanks.
