Padstones and spreader plates
16 Dec 2012
Essex
Hi guys I'm doing my own loft conversion, I have full plans passed and the steels arrived yesterday, I have 1 going into a spreader plate in a party wall and resting on a padstone the other end, another 1 on a spreader plate in the party wall which is bolted together to the 3rd beam , this join sits on a padstone, and the end of the 3rd sits on a padstone too.
I was wondering how the spreader plates are attached to the hole i made in the gable ends please? Do they just sit on a bed of cement? And does the steel just sit on top of the spreader plates and padstones?
Why aren't you using all plates (or all padstones) for all the beams instead of a mixture? That would be much easier
You bed the plates on a solid 1:3 mortar bed. The beams just sit on them and the wall made good to restrain the bearing
Thanks alot woody, umm I don't know why really! I'm running the new joists in between the old ones with a small gap and figured that a padstone would be easier in some places as I wouldn't have to raise it up unlike a thinner spreader plate . And in the party wall I figured a plate would be better as I wouldn't need to make as big a hole.
I'm assuming the padstones just sit on a similar bed of mortar too? Sorry one last thing, the load bearing walls the padstones are going onto have a 4x2 strip of wood ontop of them ,do I need to cut sections out where the padstones are going and replace with an engineering brick or pop them directly onto the wood?
Thanks again
I don't understand that at all!
As for padstones, they are built in just like a block or brick would be
