Paint looks like its got water running on it - Matt finish
25 Mar 2009
Staffordshire
Just joined and hoping to find a easy solution to my latest problem.
When we moved into our new house the kitchen had silk finish walls, maybe proper kitchen paint even. I decided to paint the walls and opted for a matt finish.
A little while later the paint all crazed like pottery glazing. I guessed it was the matt over silk so put a layer of primer on to seal the walls. This was a white layer and seemed to be a gloss like finish.
After this went back to the matt finish and all was good.
The finish is fine but now I see the walls are starting to get what looks like water marks.
I guess its condensation as no leaks, and my theory (for what its worth) is that the moisture hits the gloss and soaks in, but cant get through that to the plaster because of the sealing layer which is probably 4 or 5 layers thick by now.
Whats best suggestion? Go over with a silk paint, or kitchen paint or somethign else???
Cheers for advice
Rich[/img]
