paint over a new wall
jia
29 Sep 2010
Buckinghamshire
HI,
I have put dulux paint over a new bare plastered bathroom ( walls and ceiling) . I did not use a primer or a sealer. The paint looks ok and is not stripping off but I think it must be quite weak.?
Can anyone advise
Is it possible to put sealer now and repaint the bathroom would the second coat paint hold if I do that?
Is there any alternative to striping it all off?
IF not what is the best way to take off the paint. Any advise would be really appreciated
Jia
Nothing can be done now, leave it up there have a few showers as suggested & see what happens; if it stays on there good enough but you will probably have problems when you try to paint over it again & it may well start to fall off after a few months. When it's starts to bubble & peel, strip it all off & do it properly next time.
If you have decent extraction in the room you might be ok.
Problems are most likely to become obvious when the paint gets wet, hence the reference to showering (and condensation) and future repainting.
If you do need to remove it you can use a steam stripper with a replaceable blade scraper.
There is an outside chance that Zinsser BIN might help. It is alcohol based and will not active the emulsion. Unfortunately it is not 100% waterproof and might allow some steam through and you will end up back at square 1.
Thinning the emulsion as per the maker's instructions is normally sufficient as a "primer".
Thinking allowed, i guess that not diluting the first coat is less of an issue for the dulux retail paint as it has a higher water content than the trade paint
If you want to test a small area then mix some wall paper paste and brush it on. It evaporates slowly. If the paint doesn't bubble then things could be ok.[/i]
