Just heat stripped my galvanised garage door as it was peeling. I now need to prime it before adding a final colour. To prevent a reaccurence of the peeling, what type of primer should I use?
Take a look at your door and see if has a sort of shimmering effect if so it will indicate that the door has been etched, if this is the case prime it with a Zinc Phosphate Primer.
