Painting Brickwork - Sealant advice
30 Jan 2007
I've got brick chimney work in my loft which I am tidying up.
Not a full conversion but having a velux window installed and also fancyhing painting the brick work in either white or magnolia to lighten the space.
What can I put on the brick work to seal before painting ? will PVA do the trick ?
What's the best paint to use ?
Thanks.
Daz
If the brickwork is sound and dry and all dust removed there is no need to seal it first. PVA will not be suitable anyway. Use a good quality masonry paint, thin the first coat to get it on as the brickwork will be very dry being in the loft all those years.
