If you have an appliance fed by say 6mm cable and you replace that appliance for a higher wattage one that requires say 10Kw, can you just wire another 6mm cable in parallel to the existing one rather that rip out and replace with 10mm?
Ring mains
He hasnt said what the appliance is. This may affect the advice given.With diversity, maybe your 10kw cooker could actually happily run on a 32amp breaker......Is it defo 10kw?
