We have a double garage that is quarter integral with the house. The idea is to convert the bit under the house to a utility room. There is a pillar in the middle of the garage which holds up the corner of the house so it is a matter of closing off two openings and cutting a door through from the hallway.
My idea is to put up studs and to use plywood on the garage side, plasterboard on the house side and insulation between. I just want to check that there are no regulations that might disapprove of this.
If this is ok, I notice studs are 89mm wide but insulation is in multiples of 25mm. Would I leave the air gap garage side or house side? Is there any issue between choosing celotex or polystyrene?
