Patio lower than lawn - drainage issue?
5 Nov 2010
I'm hoping to extend my patio outwards by about 1.5 metres.
As you should be able to see, my so-called lawn is higher than my patio.
2016-06-05-09-31-31-jpg.100141
After testing a power washer on slabs, the water really builds up against the bricks so I'm wondering if the current set-up has been poorly designed in terms of drainage.
When a patio is lower than the lawn then obviously the water can't run off it so should a drain have been installed or is that not necessary? What's the usual procedure?
I'm sure a French drain would do it but there's nowhere to run it off to. Also I'm really on a budget especially as this all might be dug up in about 2 years’ time for an extension.
One thing to mention, if you look to the left of the photo (closest to the bottom) there is a gap in the bricks and coincidentally there is a hole in the lawn about 2 metres directly up (not shown) that seems to have a pipe leading to this hole. Just wondering if that's supposed to be some sort of drainage although it's not doing anything apart from spewing out debris onto the patio after a downpour.
Thanks and hope you can help.
