Pation Lighting
22 Sep 2004
I'm just about to re-point my patio slabs and have taken out all of the old, dirty sand.
There is a security light on the outlisde wall and i'd like to use the wiring, removing the security light (extend it) and run the cable under the patio flags before i re-point.
The security light doesn't have an inside light switch, so how would i go about wiring it all up?
I want to use the new wiring for a patio lamp post or similar.
Thanks all......
Andy
you will need to run a swa cable buried under the patio slabs to the new position.
it wont look nice running up a wall though
this is notifiable to your local building control department (I THINK), may be cheaper to get an electrician to do it.
anyway, a plastic adaptable box is fitted where the light was, and SWA cable run into the ground, to where you want the new light. There, fit another adaptable box to make off the SWA in (this can hide inside the base of the patio light).
You could run another black flex to an outdoor switch or a PIR, from the first adaptable box, and wire it as you would a normal switch (see for reference diagrams)
