Hi I am about to get the houses first periodic inspection for landlord purposes. I am sure many faults will become apparent but there is one that I am fairly sure will fail so will look to get it done before the inspection.
There is a spur coming of the ring to a fused outlet for a sanilflo. This fused box then feeds a double socket, this double socket then feeds a single socket that the boiler and CH programmer are plugged into. So basically its a 3 stage spur which I am sure is not compliant !!!
If I connect the double socket which is the centre of the threesome back into the ring will this make it compliant ?
Also I have a gas pipe running through a wall with an electric cable going through the same hole almost touching. Is this ok or should there be some additional insulation between the gas pipe and electric cable.
Thanks for any advice.
