Hello everyone.No brake lights.The wire that goes into the brake pedal switch as come out,i know thats the problem because it happened a couple of weeks ago.Is it an easy job to do,also as anyone else had the same problem.
my mate had this problem on his, it is easy to change however the connection in the switch may have corroded, get another one but count the theads you unscrew and make sure you fit the replacement at approx the same place and test it before going out the lights should come on just as you touch the pedal, have fun!
