Dont think this ones been posted here before.
An aircraft is standing on a very long runway that can move (a conveyor belt). The aircraft moves in one direction, while the conveyor belt moves in the opposite direction. This conveyor belt has a control system that tracks the aircrafts wheels speed and tunes the speed of the conveyor belt to be exactly the same as the wheels, but in the opposite direction. There is no wind. The pilot begins to add thrust to the engines...
Will the plane ever take off?
the question you write describes an impossible situation.The aircraft moves in one direction, while the conveyor belt moves in the opposite direction. This conveyor belt has a control system that tracks the aircrafts wheels speed and tunes the speed of the conveyor belt to be exactly the same as the wheels, but in the opposite direction.
Softus said:This conveyor belt has a control system that tracks the aircrafts wheels speed and tunes the speed of the conveyor belt to be exactly the same as the wheels, but in the opposite direction.
Can you be sure??This is getting silly.![]()
Xerxes gave us the answer many posts back. The plane is driven by its engines, not its wheels. The only effect of the conveyor belt will be to increase the drag of the wheels and so the pilot will need a little more thrust than usual.
There is however one paradox in the original question:
As the conveyor speeds up to match the wheel speed as stated, the wheels go even faster. This is a runaway runway!![]()
If you try to do this the wheels will eventually disintegrate but, unless a piece of wheel smashes into an engine, the plane will take off anyway.
going round and round in circles can continue indefinitely, but does not turn a nonsense question into a sensible one.Can you be sure??This topics been going a bit longer than when xerses got involved.
Nonsense??going round and round in circles can continue indefinitely, but does not turn a nonsense question into a sensible one.Can you be sure??This topics been going a bit longer than when xerses got involved.
Oh well I suppose you have a point.definitely.
doitall said:A wing is shaped so that the airflow speeds up over its upper surface. This results in a lower static pressure above the wing than below it and so a lifting force is created.
No air flow, plane go nowhere.
