Pipe Blanking
14 Jul 2009
Aberdeenshire
Folks,
I am currently removing a shower enclosure from our extra toilet, with the intention of using the freed space for much needed storage.
The shower has hot and cold feeds on 15mm pipes and, once the thermostatic control unit is removed, there will be a 4" gap between both feeds (pipes facing each other, with the pipe ends fitted with a compression nut which tightened onto the control unit.)
Any thoughts on how I could blank these, so I can leave the pipework behind the wall for future use...???
I do have 15mm blanking discs, but because of the arrangement on the pipe ends, these are no use...
The cold feed is mains fed, the hot is gravity from the hot water tank.
Dougie.
All Dead legs must be removed and plugged as near to the source as possible (Building Regs Part G3.) ;)
