- Joined
- 22 Feb 2006
- Messages
- 327
- Reaction score
- 17
- Country
When the room stat turns off on my oil-burning Firebird S90 boiler, it cuts the pump, too. Had a pipe stat fitted by an electrician, then had an extension and the boiler was moved and the stat refitted by another electrician. Just looked at his handiwork and currently it's spliced into a permanent live (the only one at the boiler control box), but doesn't redirect to a pump live, so it doesn't do anything.
Is it a case of me tracing the pump feed in the boiler's control pack and sticking a branch off the live feed to it? Ie live into pipe stat, live out of pipe stat into existing pump feed.
Reason for wanting to get it operational is boiler heat build-up. When the boiler's turned off, excessive heat trips the safety cut out.
