Afternoon all,
I've been looking to replace my outside pir and lights (currently a standard bayonet filament light in an enclosure) and PIR (taken off a flood light) which is no longer working - I think its staying on regardless of the switch inside on or off (so i assume water ingress).
I was thinking of using LED rope light outside along the top of the porch pointing down (the use of the light is really to identify the step leading to the front door and also to provide enough light outside to be able to see who is standing there from inside the porch not light up the whole drive, street and neighbors house). The light i've seen uses 36W total for 2.5m, and i have seen a suitably rated transformer/driver for led lights, but can not seem to find a PIR which states that it is for outdoor use but can switch low loads. Most that i find are already attached to LED flood lights or are rated with a MAX wattage but no mention of a min.
is anyone able to recommend me any suitable PIR's? I'm happy to order from any UK based online seller, or standard shops (screw fix, tool station, wicks etc). Alternatively, the suitable words i can use to search for in google will also suffice!
