Hi
Soon I will be installing a bathroom In-Line Duct Ceiling Fan with Timer - voltage 220-240V
I have read that it needs to have an accessible fused connection.
MY QUESTION
To save having a pull switch or an outside the room switch, is it feasible/possible to connect
a PIR, so that whenever someone enters the bathroom - regardless if the lights are switched on
or not - the fan switches on automatically, and uses the built in fan timer.
Trying to get the family to remember to use a fan manually is a problem.
This PIR would be fitted someway into ZONE 3.
If it is possible can you direct me to a wiring diagram.
I was thinking of something like this from Maplin;
Outdoor PIR Light Control Device - Specifications;
Detection method: Passive infra-red
Power requirements: 230Vac 50Hz
Standby current: 30mA (max.)
Operating current: 35mA (max.)
Lighting load: 1100W (max.) incandescent
500W (max.) fluorescent
Detection range: 12m min. at 20 C
Detection angle: 180
Adjustable angle: Vertical 180
Lux level: 0 to 1000 lux
Housing design: Water resistant
Lamp-on time: 5 secs ±3 to 12 mins ±3
Many thanks in advance.
Stephen
MY QUESTION
Stephen
