Hi
This weekends project is to plasterboard over existing lath & plaster ceiling which is in ok condition. My plan is to mark out the joists which run horizontally across (90 degrees to floorboards) and attach into them.
I am doing this as the plasterer will be in shortly to plaster ceiling and walls, so time is key and removing old ceiling is not possible
Just wanted a bit of advice please? What is the easiest way to get the board up to the ceiling and what screws or nails should I use? 12.mm pb thought maybe 40mm screws? What spacing between? 150mm?
Any top-tips I should be aware of, how thick is the existing ceiling likely to be, as this will aid me in deciding on screws?
Many thanks all help greatly appreciated
