I have recently modified a utility room by replacing the existing 90 degree corner to one which is at 45 degrees. I re-built the stud frame and applied new plasterboard on the new studwork. When applying the plasterboard I noticed it does not join exactly to the original and I have gaps of about 3mm. Is this something the plasterer will be able to overcome or should i try to fill the gaps with something.
an
an
