Please help having problems with boiler!!!
14 Dec 2012
Sheffield
Ive attached a pic of boiler its a isar he30 as you can see pressure is really low ive tried filling the tank by attaching the pipe and opening valves but nothing happens can some1 please help
I cannot see any attachment.
The double check valve may be jammed!
Or you can call a plumber!
View media item 53743
I have marked the valve that you need to open to fill your system, you will need a flat headed screw driver, as said if that does not work try tapping the non return valve gently , it may be jammed.
