Hi guys I could really appreciate some help please.
I have noticed damp coming into the garage walls by the lower brick walls, and it seems to be a patch of damp on the actual floor.
I have moved all the stones which is the other side of the wall, and noticed a hole underneath the drain pipe.
I filled the gully with water, and most of it stayed where it was, however when I filled the hole with water, it slowly drained away.
Im sorry if this is a silly question, but does that hole need to be filled in and could that be the cause of the damp which in the garage behind?
And would a coat of bitumen on the garage brickwork help?
Or would that hole lead to something, as I can not understand how water would drain away if not?
Thanks everyone
Alexa
Thanks everyone
Alexa
