We have a Baxi 105e boiler, no more than four years old.
Expansion vessel replaced 10 days ago, we knew it was on the way out, pressure needed to be topped up every week then every few days, heating otherwise functioning fine.
Had new wall-mounted expansion vessel added and new thermostat (wireless) as engineer realised old one wasn't communicating.
Thermostat didn't work though, engineer came back, said the router was interfering with it, moved it away from router, seemed to work for two days.
Then heating stopped working reliably, hot water is fine.
Heating often won't come on, whether thermostat is in use or not. The times it does come on, it heats up and then switches itself off. Boiler is still on and making noises.
Engineer came out for third time today, first blames dripping tap as he said the hot water light keeps flashing which means the boiler is heating water secondary to putting heating on. Taps all turned off tight, so that's not the problem.
Then he says the new wall mounted pressure vessel means we have lost the pre-heat function the original pressure vessel provided -- not too happy about that and were never told about it, but turning off the pre-heat function doesn't help.
Now he has said the valve which switches between the hot water and heating isn't working properly? And that he has to order parts and we've now got to freeze until Wednesday morning, with heavy snow due tomorrow.
I'm sick of this, the heating was working fine other than the pressure issue before the expansion vessel was changed.
Any other ideas anyone? Is it worth calling someone else out? Is it a coincidence that this valve has seized and we have only had problems since the boiler was first "repaired" ten days ago?
We are freezing, any advice welcome.
