Hi I'm hoping someone can help or at least point me in the right direction.
I have a plumbase 2.0 bar shower pump fitted in my airing cupboard at bottom. It has a dedicated 22mm cold feed from cold water tank in loft and a 22mm hot water supply fed from a surry flange. It then runs off in 22 mm under the floor boards about 2 meters until it reaches the bathroom where it goes to 15mm and runs up toward the shower mixer. The shower mixer has a fixed head and and smaller movable head. My problem is when I go to use the shower nothing happens unless I move the shower head down or give it a really good shake. Another problem which I'm sure is linked is sometimes when u turn the hot tap on in the kitchen the shower pump will start for about a second and sometime pulse every couple of seconds.
I though this could be air and have removed the heads and runs the water through and have never heard air gurgling and it has never fixed the problem so any help would be much appreciated. Hope ive included enough info! Thanks
