- Joined
- 30 Dec 2021
- Messages
- 10,856
- Reaction score
- 1,802
- Country
Kitchen taps here but same principal to remove yours.
Could you post a video of how to hang a boiler?
That’s just four screws innit?Could you post a video of how to hang a boiler?
I don't get the bit where he has cut the pipes off (they're in his hand) and then removes the olives. No mention of new pipes to screw into the tap.Could you post a video of how to hang a boiler?
If there's enough movement in the supply pipework, can pull down to free the tap pipes, then unscrew. Then undo the nut and remove the tap. If not, remove the nut first, then lift the tap to free the pipes. then unscrew the pipes. Re-use the pipes, which are likely to be bent to suit the feed pipework.
Yes, but I don't see why he has to cut pipes and remove the olives. No mention of new pipes (or flexis)All jobs are different. What's the chances of him demonstrating the exact job you need to know about
potential partner
Good tip in the CC on how one can remove stubborn taps
I wouldn't recommend charging £20
I don't understand the question.So.. am choosing replacments now, does the width at connection of the tap have to be EXACTLY the same, or can we shove some glue or whatever in there to bridge the gap. From my finesse, you can see my plumbing skills I bet.
The new tap will probably come with flexi connectors which you will need to fit to existing pipework.
Everything else will be the same.
