Hi all
The missus has been nagging me for a mixer shower and P bath.
Our old bath has the taps under the window, so we had to go for a right hand P bath.
This will be on the opposite wall facing, behind the door.
My dilemma is plumbing it in and how to go about it, i can solder pipe etc, but it where to run the pipe and then finally connect up.
I am thinking of running pipe work from my existing feeds on the original pipework at 150mm centres under the bath, up to the mixer shower soldered connections with an isolation valve on each, but this is where i am getting frustrated, then i have to make connections to the bath taps with seperate isolation valves on the same run but they also will be at 150mm centres, so what is the best way to connect these pipes, as shower pipes and bath pipes will be to close to each other?
