In an emergency they can be made to fit with a lot of PTFE tape.
Its better to use a special solder conversion coupler.
Its possible to get 3/4" olives to be used in a 22 mm compression fitting and they usually work ok. I would use them with care and silicone grease to lubricate the joint when tightening.
