I've encountered many plumbers that say "ouch don't touch the stuff..." and you then quiz them as to why and they haven't got a clue, they haven't ever used the stuff, don't know a thing about the range of fitments and can't give a truly constructive response
In no particular order, just a few of the 'clues'
*Plastic embrittlement.
*O-ring embrittlement.
*Sagging, causing airlocks and looks a mess even if carefully laid.
*Fittings too bulky for concealed areas.
*Doesn't bend properly.
*Pipe cheaper but fittings far dearer.
*Speedfit outer nut can split in modest cold temps.
*Pipe fails spectacularly with frost, whole lengths split, so no spot repairs.
*Looks cheap.
*Not new, been here for decades survives through perceived cheapness.
*Less hygienic than copper (microbiological growths).
*Is only quicker to fit for those who have limited skills.
*Guarantee worthless as chances of proving faults are slim.
*Rodents eat it.
*No recycle or scrap value, old stuff ends up in landfill.
Furthermore heat loss only matters where it doesn't contribute to the heated space, (lofts garages) in which case all pipe should be insulated.
Copper is only noisy if carelessy installed.
It's fine for DIYers (and for UFH uses), but to me calling yourself a professional plumber and using speedfit is like making microwave ready meals and calling yourself a chef.
It's professional, not old plumbers who hang on to copper. The advantages you've described only benefit a DIYer or someone who wants to use a product which is more forgiving to shoddy workmanship.
