Hi, moved into my house 6 months ago-had to do a lot of renovating and replaced all taps with monoblock type HP taps.
Set up I've got is:
1) Vokera Mynute 28kw system boiler running around 14 rads
2) shower pump running two ensuite showers -pressure/flos is fine here
3) the cold water flow is better than hot water -about 9litres/min
4) had a new water mains line put in -hasn't made much of a difference to cold water flow
Problems I've got are:
1) boiler needs to be more powerful -looking at a worcester 40cdi -converted to run as a system boiler
2) thinking of a megaflow cylinder -which I think will give me better hot water flow -to match that of the cold flow
3) been told that my pump will nto work to power the two showers
I am a bit concerned that I will lose power in the fairly large shower I am currently running with the pump.
Any advice?
Set up I've got is:
Any advice?
