Pop-up waste (of space)
15 Nov 2005
South
Cook Islands
what a splendid site this is!
I have a leaking pop-up waste, which having looked at some other posts seems to be quite usual.
It is of course tucked away out of sight, I have been able to get a couple of fingers to it and it seems to be dripping from the knurled screw-on ring that a horizontal rod goes into to lift/lower the plug.
I doubt I will be able to get at it without demounting the bidet, luckily I specified flexible braided tap connectors though the waste looks to be solvent-welded so I suppose I will have to cut it.
I don't want to ever take it out a second time, why do these things leak and can I reliably fix it? Would it be less trouble to fit a new waste with a plug?
less trouble to get rid of ur biddet......what u use it for ?
JohnD. By the sounds of it you must have a massive rambling mansion. I don't know how you find time to post on this forum. Every day you seem to have some sort of a problem or need advice on how to do things. Are you running a hotel, the list of jobs you have to do keeps getting longer. Good luck I'm sure you will get on top of things in the end.
:LOL: not at all! just got behind on a couple of things I don't know how to do! :LOL:
You're right, I'm wasting my time on here to avoid getting round to them! :cry:
You need to adjust the ball which covers the hole by moving it along on the rod until you get a seal.
Not done one on a bidet but assume it is the same as a basin. :D
Ball, Rod :?: , Get on your knees, it`s lower than a basin ,otherwise the same.smear the ball with lsx,or ky whichever is to hand
