Hi all, i have an Alpha CB24 Combi Boiler, it's approx 5 years old. I noticed towards the end of last winter that when boiler fired up to heat rads it would ignite 2 or 3 times before it fired up and stayed on, i didn't worry to much as the heating was working ok and hot water was also ok.
i've recently had boiler serviced and i mentioned this to enginner. he advised me that it was probably a fault with the flue, he said it sounds like the clips on the bend had cracked on the inner pipe and it needed replacing ?? he told me to check flue in loft to see if pipe was warm on the bend when heating on and it was.. Does this sound right and if so, is it an easy fault to rectify ...
