Potterton boiler puma 80
11 Nov 2008
Yorkshire
I have a potterton puma 80 boiler.... and its on the blink
The pilot light has suddenly stopped working. I can light it manually and it stays on for about a minute, then it turns off and the boiler makes a hissing noise.....
I think it may be overheating, but not sure.........
Any ideas and whats the damage £
Cheers
Pump / wax capsule / airlock.
When you say it stays on for a minute, do you mean the burner lights for a minute?
Does it do it on both Ch and HW
Yeah when i turn the pilot light on the boiler kicks in , the flames rise for around a minute then the hissing begins, steam escapes from the top of the boiler and the pilot light then turns off.
Does it do it at all/ similarly/ almost not at all, on hot water?
If it's much less bad it's the pump, if similar, likelly to be boiler full of air or blocked.
Ive turned the central heating off and manually lit the pilot light , then tuned a hot water tap...... nothing happened yothe boiler the light remained lit but i didnt get any hot water
