Potterton Electronic Progammer
3 Sep 2008
Cheshire
Hi - I have a potterton EP which looks like the EP4002 but in brown. Last night (hottest of the year!) my central heating came on even though the slide was still switched to off. I fiddled with the switch and eventually resorted to pulling it out to check the contacts but the only way to get the heating off was at the boiler.
Before I go the expense of installing a new EP can anyone tell me if there is a way of diagnosing and fixing the problem? Could it be battery related?
My wife is going mental because I installed spotlights in the kitchen at the weekend and she is convinced the problem must be related so any help would be much appreciated!
Jim
It will more than likely be a faulty motorised valve than the programmer
namsag - thanks for the quick reply and forgive my ignorance but what is the motorised valve - is that in the boiler?
seco - thanks for your help. unfortunately those links are blocked by my work IT administrator so I will check them tonight.
I should have mentioned that the red light on the EP stays on even when I move the switch which is what made me think it was a problem there rather than anywhere else.
the red light is probly just a backfeed on the clock. even if the prog was on, if your room stat is down then the heating shouldnt come on. certainly a mid pos/zone valve issue.
gavinda, thanks. That would make sense, although we have radiator valve controls rather than a room stat and had the patio door open because it was so warm, the valves were turned on full from the last time we had the heating on.
I've turned the radiator dial on the boiler down to 0 and all the radiators off so at least we can get hot water until I can get a CORGI guy out to look at it.
