Have a Potterton Kingfisher MFL 60 which was installed feb 05.
Gravity CH system with potterton 2000 timer/control.
Been fine till 2 weeks ago when red lock out light comes on few times a day. Some times will run for 2-3 days and other days will cut out 5-6 times. Water very hot in tap and rads.
Bled rads and pump. Checked header tank - half full
Water temp seemed erratic so changed the cylindar thermostat but this had no effect so called out BG as had taken out a homecare 4000 10 weeks prior.
BG man turned up but as they had forgotten to do initial inspection promptly decided the lourve door was a ventalation hazzard and slapped a label on stating the device was a hazzard to life and property.
Said he could leave on if there was a carbon monoxide alarm or if we would get one and had one in his van (£38). Felt like had to say yes or be cut off!
He also decided that CH controller was wired incorrecty as we have to have HW on before we can select CH. Been like that since we moved in (10 yrs) . Looking at potterton, honeywell etc replacements for the EP2000 it seems that this is commen practice.
I was left details that ventalation needed to be 198 cm2 high and 396 cm2 low. total - 594cm2
I calculate that my lourve door is 4mm gaps x 52cm long x 49 gaps.
over 1000 cm2 .
Looked on here for prevoius postings and decided to change the boiler thermostat and thermister.
Still have a red light happening notice that when flames cut out there is a lot of clicking like flicking of a switch rapidly a dozen times.
Any ideas what next step is ?
Have BG technical manager coming for a second opinion 4th jan so just wondered if others think the BG engineer was right or wrong.
Cheers
Ian
over 1000 cm2 .
Cheers
Ian
