Hi there, new here 1st post.
My boiler has decided to pack up for the first time in over 15 years, before I start I'll fully aware of dangers of working with this type of boiler hence will be calling a Corgi engineer in due course. However as like any other DIY'er I am keen to know roughly where my problem is before being potentially fobbed off with £££'s signs flying in my direction.
I have made a quick visual diagnostic and this is what happens:
1. Timer unit switched on and calls for heat/water
2. A loud click from the relay I presume and the fan starts as usual.
3. Shortly after another click from somewhere and I can clearly here the ignition module doing its business (continuous clicking) and I can see the spark being generated through the little window.
4. Then no flames whatsoever can see nothing through the window apart from the spark being generated continuously.
I suspect the Gas Valve not opening, anything else could be faulty?
many thanks
many thanks
