Hi, i have a Potterton Netaheat profile 60e, which requires manual startup via the button on the underside of the boiler.
I set time for heating and hot water and sometimes it comes on sometimes it requures manual start up.
At first a plumber thought the power socket was the problem, this was changed and i even plugged it into a seperate power supply the same intermittent manual start up was required.
Quite an annoying problem because in the mornings when you wake and expect hot water its not there because the boiler never fired up!
Once manual started up it functions fine.
Suggestions would be welcomed.
