My potterton performa 28 boiler works fine heating the radiators but has just started to cut out when heating water! it will heat water until the lights reach 80 the the flame cuts until the lights drop down to 40 the re-ignites, it will continue this cycle until you turn off the tap!
the pressure in the system is @ 2 bar.
I seem to remember it doing this about the same time last year (when the temerature warms up and the central heating is not on as much dunno if that helps) my plumber came in adjusted it to a point where it would be ok but only if you kept the temerature dial turned almost all the way down (so not properly fixed).
any help would be most appreciated.
