There appears to be an intermittent problem with my 2 year old Potterton Profile 80eL boiler, in that the pilot light has failed to light twice recently, and sometimes seems to take a long time to light. Normally, it lights after one or two sparks, but recently, can take up to a minute of sparking to light.
When the system calls for heat, the fan starts as normal, followed by a click, and then the ignition spark starts clicking, but the pilot light does not ignite. There is a slight smell of gas from the flue, so it appears that there is at least some gas being supplied to the pilot. The spark does not appear to be particularly strong, and it tends to vary in strength, but there is definitely a spark. When the pilot does light, it appears to be the right shape and size as far as I can tell in the brief period until the main burner ignites.
From looking at the fault-finding guide, it appears that the most likely culprits are:
1) Solenoid GV1 not working consistently.
2) Electronic control failing.
Another possibility could be contamination on the pilot light jet causing the gas to be (sometimes?) diverted away from the spark (boiler serviced around 9 months ago).
Before getting someone in, I would appreciate some advice from people on this forum about what is the most likely cause of the problem, given the symptoms and type of boiler.
