As per title, there's a slight drip of water from the LHS rear of the burner tray. Only spotted it after the boiler started showing symptoms of either a faulty sensing electrode or blocked condensate trap (5 ignition cycles then lockout). Unplugging the trap sensor cured it, but then I noticed water on top of the trap, which was shorting out the sensors.
I don't know if it's condensate or system water (can you taste the difference? And do I really want to be ingesting X100??). This doesn't seem to be a common place for these to leak from. I can't see where the leak originates from.
This boiler is really on it's last legs and has a history of kettling so I'm fearing a rotted/leaking heat x, unless anyone has any other ideas???
Cheers.
Cheers.
