Problem with boiler now cutting out on over temp. then recycling causing shower problems . Have changed the NTC sensor without success. Also the divertor valve changed as a lot of gunk coming from the heat exchanger was evident. The 22mm CH feed pipe is as hot as the 15mm DHW feed even on DHW only. Before considering replacing the PCB urgent advice required
Dauvit
Dauvit
