Potterton Suprima 100 won't start!
2 Nov 2004
I've just tried to use the central heating system for the first time since last winter but without any success.
The current state of the boiler is as follows:
The electricity supply is switched on. The external timer is on. The room thermostat is on a high temp setting. The boiler thermostat knob is on a mid-high setting.
The pilot light is out.
The red LED is lit but the green LED is not.
If I press Reset, then the green lights up whilst I hold down the reset button and I hear some vague noise in the pipes(?) But the green light goes out again and nothing happens.
Am I missing something obvious or does it sound like an expert needs to have a look?
Any help would be really appreciated. :rolleyes:
Sounds like it's "locking out" because it thinks something is wrong. Roughly how old is it? Recent ones less than a year I think) need the pump to be running before thay'll start, yours could be stuck. But older ones didn't care.
Does the boiler heat the hot water as well - ie during summer?
It's about 2 years old.
I'm not sure if the fan is running. However, if I should be able to hear it, then it's not! Ditto with the pump.
We don't use the boiler for hot water.
I can't hear a fan or pump so I guess that means that it's not working?
are you sure the proggrammer is switched on :?:
Status Green LED Red LED
Mains ON Only OFF ON
Ext. Call for Heat FLASHING ON
(Boiler set to STNDBY, 2 Per Sec.
Temp. Control set to 'O' Off)
Ext. Call for Heat FLASHING OFF
(STNDBY switch to ON, 2 Per Sec.
Temp. Control set to Max.)
Ignition FLASHING OFF
(i.e. Gas and Sparks ON) 16 Per Sec.
FLAME Detected ON OFF
Boiler Temperature FLASHING ON
Control Satisfied 2 Per Sec.
Lockout OFF FLASHING
2 Per Sec.
hope this makes sense to you :D
