- Joined
- 30 Oct 2006
- Messages
- 6,743
- Reaction score
- 367
- Country
Check that you have not got a blocked cold feed. It will be the pump overrun control which is keeping the pump running. Any suggestion that the pump and not the boiler is controlled by the end switches on two port valves is nonsense.
If it is an installation with two 2 port valves [known as an S Plan], there should be a bypass before the two valves so there is still circulation through the pump during overrun. It is commonly omitted.
It would not be nonsense if it was wired up without using the PL on the boiler, as already explained
but it's not so it is.
