power flushing
4 Sep 2007
Sheffield
Id not heard of this until i got a flyer through the door the other day
Is it better or as good as the traditional methods ,does it have any drawbacks and how would you expect it to compare cost wise to the traditional drain and flush methods
First of all do you need one? Best check is to remove a small radiator & empty water into a bucket (not a black one) if water is clean you generally don't need a flush
so this guy is touting for trade... run away. you'll only need a powerflush if your heating eng tells you so.
as long as your rads are heating youve got no leaks and you are happy with your gas bill, carry on regardless. use the money for a boiler service and stick the rest in a saving s account.
if you have an old, vented system, it is likely to have a lot of old sediment in it.
however, as long as it is still circulating with no blockages, you can do quite a lot of good by:
baling and sponging out the mud from the F&E
running Sentinel X400 in it for 4 weeks before draining and rinsing. It is very mild and will not damage your old system.
refill with X100 or similar
the chemicals will cost you £15 each so you will be £££hundreds in pocket
If you are energetic take the radiators off and squirt them through with a hosepipe first
If you can do simple plumbing and afford £100, fit a Magnaclean or other device as well, I guarantee you will be amazed and delighted at how much muck it collects, and it will probably prevent you getting a blockage in future.
If you want to do it in a few hours you could run Sentinel X800 for a hour or so (well so I've heard).
