I've just installed a power shower trition as2000xt (similar to electric shower) in a friends home which consisted of a hot a cold feed. In the booklet it says not to bring hot feed up over and down but this could not be avoided seeing as its in an old cottage and had other rooms in the way just to bring a feed straight across. He didnt want me chasing floors and walls to bring feed from under.
This shower was a gift last year and it didn't have the push fit connections for inserting into feed outlets with it so I welded up some copper pipe and bends to suit, let cool for awhile then installed to shower which connected to compression fittings. This cottage is miles from anywhere so couldn't go and source the exact push fittings needed. I know its not recommended to use copper fittings near the shower as when soldering/welding, you can destroy the shower with the heat of the blow torch but will these copper fittings be OK in the long term with the amount of heat generated by the shower. I'm wondering should I go back and remove copper and replace with plastic push fittings or am I overthiking things.
