power shower
26 Oct 2003
i would like to install a power shower in my 3rd floor flat. only i have a very small hot water tank, which is under my kitchen drainer, and a very low level cold water tank. is it posible? also would i have to run a seperate cold water supply from the cold water cisten?
Say a minimum of 9 litres/min for 7 minutes, thats 63 litres. How big is your tank? Unless you have a combi boiler you need to change your tank. If you have a combi boiler, you wont need a power shower, as you can run a shower directly. Otherwise have an electic shower.
hi, i tried a water test and it run for the time you said. my hot water tank is 30 inches high and 17 wide. will this be ok?
