I have a semi detached house that was built in 1974 that has what I believe to be a precast flue,
This also has a chimney breast that is around 120mm deep so about a brick width
It is around 1700mm wide in the living room and runs up through the master bedroom where it is 700mm wide then halfway up in to the loft space where the flue connects to a metal flue pip then to a ridge tile.
I am wondering about removing this flue and breast to leave a flat wall
does anyone know if this would be possible without too much work and would it cause any implications with/for my neighbour? apart from the noise when removing!
Any info most appreciated
