Professional flat roof advice
8 Mar 2020
Hi
Wonder if someone can give me some advice. We had a new flat roof installed last year and it looks a good job by a reputable company.
We discovered a leak recently and they come to look at it and added some sealent over the existing seal. I'm a bit concerned this isn't the best remedy if the seal underneath is failing?there is a hole in it etc.
They have said they will cut a new flashing if this doesn't do it, but worried it's a quick fix/ poor patch job.
Any advice from any roofers recommended, also if there is anything you'd recommend me doing as a better repair or adding to it?
The roof is a flat roof extension, using a rubber membrane and it's being cut into external pepple-rendered wall.
Can supply pictures if it helps
Cheers
Have uploaded some pictures for reference
Anyone have any advice on what sealent to use on rubber flashing ?
